Archived from groups: rec.games.video.arcade.collecting (More info?)
Wondering if anyone else has run across this...
I'm running Clay's SW/ESB kit and the games play ok, but I noticed I'm
missing specific graphics entirely...
I found an atari service bulletin that stated exactly what I'm running
into...
MISSING STARS
Problem: During the attract mode or game play, the screen may not show stars
or only one star. In addition, lights may not exist on the surface of the
Death Star so that the towers look like they're floating in space. The
problem usually occurs when the game is first powered up.
Short Term Solution:
Turn the power switch off and on until stars reappear, or short out the rest
test points on the Main PCB
Long Term Solution:
Change the EPROM on the Main PCB at location 1F from a part number
136021-114 to a 136021-214. All games built after the following serial
numbers have incorporated the above EPROM change: (UR9275 and SD1388)
I can't do the on/off trick to bring the stars back, but do get only one
star at the beginning of the attract screen that flys away and then nothing
again... I also get the issue where the towers look like they're floating.
Problem is, the kit replaces the 1F rom... so I can't exactly swap that
out..
I'm going to recheck the install one more time, but thought I'd throw this
out there to see if anyone's been down this road before..
Pete
into...
MISSING STARS
Long Term Solution:
out..
Pete
