static IRQ for my WinTV PCI Card
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi,
I have a ASUS 7N8X Deluxe Rev. 2 Mainboard, running BIOS Rev. 1008.
I would like to gave my WinTV card a static and own IRQ, but I couldn´t find a possible entry in BIOS Setup under "PCI & PnP Configuration". There, I only could reserve a IRQ for a none PnP Card (but that doesn´t help me out). :-(
On my OS (Win XP SP2), I couldn´t set a static IRQ.
Are there any other possibilities?
Thanks
Carsten Remien
(Use ROT13 to see my email address)
On Mon, 8 Nov 2004 21:57:39 +0100, "Remien, Carsten"
<arjf.erzvra@tzk.vasb> wrote:
>Hi,
>Thanks
>Carsten Remien
If you are looking to assure that the slot has an exclusive IRQ
assignment, you are out of luck since all 5 PCI slots share resources
with other slots and various onboard peripherals. The chart on page
32 of the manual indicates the following:
PCI slot 1 shares with slot 5 and the WiFi slot
PCI slot 2 shares with the AGP slot
PCI slot 3 shares with SATA devices
PCI slot 4 shares with the Gigabit LAN adapter
PCI slot 5 shares with slot 1 and the WiFi slot
Now, if you have nothing in slot 1 and you are not using the WiFi
slot, then you can put the card in slot 5 and it will have an
exclusive resource assignment
Additionally, if you have no SATA devices, then PCI slot 3 will
receive an exclusive assignment.
With ACPI enabled, XP will make virtual IRQ assignments and pretty
much any conflicts that might have been a concern in the past, will
not be an issue today.
Are you experiencing issues with your current setup, or just trying to
plan so you don't have any issues?
Regards,
Ender
"The only thing necessary for the triumph of evil is for good men to do nothing." Edmund Burke
"Ender" <enderwiggin3rd@SBhotmail.com> schrieb im Newsbeitrag news:53svo05ac7i5ehegk2uk70sohke6n8jhen@4ax.com...
Hm, Slot 1 is free and when I put the TV Card in Slot 5, it share´s it with "NVIDIA PCI to USB Enhanced Host Controller".
The same as Slot 5 :-(
(SATA is disabled)
I have also tried with APIC enabled/disabled.
I think, I have to create two Hardwareprofiles, one as now, the other with disabled USB Support.
(SATA is disabled)
Why? XP can do the IRQ sharing without a problem. If it doesn't work then
it's a driver issue.
