[SOLVED] Static shock from front USB ports?
mike2012
338
Okay here's my situation. Where I live it is currently winter and my PC is in a room with dry air. So the problem is that sometimes when I try to plug something into one of the front USBs ports, I will feel a static shock. At least one time I could see a visible static shock when trying to plug something in the USB ports. After the static shock however, if I try to plug something in the USB port it works fine.
The ports still work fine, but is there anyway to stop myself from static shock everytime I try to plug something in the USB ports?
