Review Steam Deck OLED Review: Console-Style Upgrade
I still regret that I ever bought a Steam Deck. They're so giant and unwieldy, but they make it look small way smaller than it is in the marketing.
If they had at least used all that extra space for a bigger and less-crap screen ... that would at least be one less thing to point and laugh at. I think I still wouldn't like it though. It would still feel like gaming on an etch-a-sketch, and still look way too silly to use in public.
With the die shrink, I would think you could Overclock and/or Undervolt to get more performance at the same power draw or longer battery life with the standard performance. Looks like a good refresh of the platform.
Reactions: ezst036
I understand what Valve is doing with the Steam Deck, but I'm still a bit disappointed that there won't be one with a decent CPU for a long while.
I think Qualcomm will likely charge way too much to land in a device like this, but a pure Zen 4c based custom SoC would probably be amazing.
I like my Ally a lot, but windows is as much a disadvantage as advantage. Valve's hardware control is fantastic on the Deck and much simpler to set than any Windows based handheld.
There's no way the original Deck had just 167 nits screen! Check your numbers. It should be at least 400, but most people measured it above 500 nits.
You're the only publication where OLED scored lower FPS than the original. It should be the opposite. Check your numbers.
There might be a bit of confusion about the Snapdragon. It's an ARMv64 CPU, which means it's not designed to execute x86_64 instructions. Consequently, it wouldn't be able to run games that require those instructions
Additionally, it's important to note that, as of now, Proton and Steam are not available for ARMv64 architecture. The only conversion layer that exists on Wine is still under development and not fully functional. That means that games won't work on a Snapdragon
Regarding the CPU's performance, it's worth mentioning that in the case of the Steam Deck, the games tested are typically GPU bound. This occurs 90% of the time, indicating that the CPU does not become a bottleneck in these scenarios. AMD is known for producing excellent APU units, which are crucial for a console like the Steam Deck, where integrated graphics play a significant role
Reactions: LabRat 891
