Hi!
I have a problem with my LTE internet. SpeedTest shows that i should have download speed of 1,5-2,0 Mbit/s and I get it with flashget downloading a file from a premium server. At the same time Chrome, Firefox and JDownloader2 downloades the same file from the same server with 200-500 Kbit / s. Steam also downloads with max speed.
I have tested ADSL connection(it is in the same building) on the same PC and chrome/JD2 was working fine, reaching max speed.
How can JD2/Chrome download with differnt speed than FlashGet the same file from (i presume) the same server at the same time? What can be the problem here?
I have tried reinstaling drivers, JD2, trying Ashampoo Internet Accelerator - http://www.speed.io/ shows that "Connects" parameter is 250 con/m which is "VERY SLOW". What does it mean?
Edit1
I have tried downloading AMD drivers and I've got around 800 KiB/s - so its closer to what my speed is supposed to be. Also if I download many files from the same server the total download speed gets around 800 KiB/s.
FlashGet has stopped downloading with higher speed.
Edit2
My thoughts are that maybe the internet provider is blocking users if there is a high load. But this does not explain why Steam was always working on the highest possible speed. Now everything is back to normal for the time being.
Edit1
Edit2
