Question Steel Series Arctics 5 no sound in right headset
Apr 26, 2022
Hello, I'm new to doing one of these. So for some context, a year or two ago I purchased a steel series artics 5 but unfortunately the sound stopped working in the right headset. Today I finally opened up the right cup of the headset and found that there was a copper cable snapped. So I was wondering is there away to fix this without any soldering? And if so are there any guides I can watch on how to do so?
View: https://imgur.com/a/NhNiLQf
Ralston18
I was not really able see the necessary detail in the image.
However, you might be able to use heat-shrink tubing.
Unfortunately, heat shrink also involves heat and I noted what appears to heat glue holding some connections in place.
Just FYI:
https://clevercreations.org/how-to-use-heat-shrink-tubing/
The fine wires make any solution risky.
If you know a family member, a friend, or co-worker with soldering skills then soldering would be the proper fix.
Ask around - someone may be able to help.
