SteelSeries Engine 2 won't start
Sulhiz
Commendable
Feb 2, 2017
Hello, Im using Steelseries Kana CSGo Edition mouse, since this mouse is not supported by SteelSeries Engine 3, i need to download SteelSeries Engine 2 to update my mouse driver. After download SSE 2 and completed installation I try to start but this error showed up.
Description:
Stopped working
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: steelseriesengine.exe
Problem Signature 02: 2.9.2014.1
Problem Signature 03: 5436e58e
Problem Signature 04: mscorlib
Problem Signature 05: 2.0.0.0
Problem Signature 06: 4ca2b851
Problem Signature 07: 1b7e
Problem Signature 08: 10
Problem Signature 09: System.IO.FileNotFoundException
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 17417
Anyone can help me?
I'm running on Windows 7 X64 SP1
Did you install the application under an elevated command?
i.e; Right click installer>Run as Administrator?
I'm also assuming you've installed SSE3 prior to SSE2 and the prior installation is yet on your system? Try using CCleaner, clean your registry and try opening the SSE2 app. On another note, I'm assuming all your chipset and motherboard drivers are up to date.
Further reading.
Further reading.
I am new here. But my Ideazon(Steelseries gaming keyboard) problems have been solved. The Windows 10 latest update screwed up my keyboard and nothing I could do no matter how I reinstalled the keyboard would work. I downloaded the Microsoft tool that hides Windows updates from reinstalling after a restart and I deleted the update and hid it with the tool. Steelseries (old Ideazon keyboard brand bought out by Steel.) Now works fine. Use the tool and it will fix Steelseries, Zboard and Ideazon drivers install problems.
