Steelseries Headset Problem
matauskas
12
Hi, I have the Steelseries Siberia v2 Full size headset with the usb card. And one time I accidently unplugged the headset from the computer so, I re-plugged it but everyprogram froze. So, I restarted and everythink was fine. However, the same thing happend again when unplugged and re-plugged the headset few days later(everything froze). So can anyone help me solve this problem?
Thanks! :)
check all your driver are up to date and also check windows updates if there is still a problem try minimizing all open apps and right click on desktop and click refresh sometimes this will kick start all the apps running to un freeze as i have used this method before and it tends to work!
