Steelseries lights up, works for 2secounds then stops working but still lights up
Tiranttt
I got problems with my Steelseries Sensei.
My mouse works at times, just seconds after I plug it in, but then stops working, Sometimes its never working at all. Its lights are enabled. I cant start engine on my own computer, but I can on other computers. My mouse works at other computers but not on mine. It starts up and works perfectly on any other computer BUT mine. Anyone know how to fix this? I dont know how or if I should reinstall my usb drivers.
PS: It's only this mouse that doesn't work.
I recently changed to windows 10, but This problem occured a while before, but not in such way as this, just sometimes stopping.
Hi,
I've had a similar issue when I had the sensei and I resolved this by changing the power options on my USB ports.
You can change your usb port settings in the power options.
You can also go in the device manager under Universal Serial Bus controllers , Right click on your usb ports -> Properties -> Power management and uncheck Allow the computer to turn off this device to save power.
Please let me know if it works!
Hi,
