Review SteelSeries Rival 3 Gaming Mouse Review: Entry-Level Without (Much) Compromise
I actually owned this mouse. And the reviewer did not discover that the rubber sides are GLUED onto the mouse meaning that they will eventually fall off if you use the mouse for extended gaming sessions. I cannot recommend this mouse. Go for a quality mouse without glued components instead.
You are mistaken, this is the rival 3 which was just released. You are thinking of the rival 300/310. I made an account just to correct you because this is actually a quality mouse with NO glued side grips.
