SteelSeries siberia v3 right side not working properly
Borbp
49
Today I noticed that my right side on siberia v3´s is not working properly. By that i mean that the sound on left side is much louder than the sound on right side. Does that mean they are broken or is there any way to fix that?
Thank you for all answers
Just as I posted that i found a solution. I kind of pushed the inside of headphones and that solved the problem? I guess the contact was not the best and that fixed it 😀
Lol, that actually worked. Thanks for your solution man I love you so much.
I was hearing some weird thing like a broken thing inside, but then I pushed it and I tested it and It got fixed. It was the woofer thingy that was the problem.
