Step-Up Ring for Sony Camcorder Lens
G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
I'm having trouble finding a step up ring for a lens with a 25mm filter
thread size. B&H and Adorama don't seem to have them. I don't care what
size it steps up to, as long as it is a relatively common filter size.
I'd appreciate it if you could help.
Thanks,
Jim
G
Guest
Guest
"takeone" <takeone@theworldonline.com> wrote in message
news:ac3ec.8130$pN3.583@newssvr23.news.prodigy.com...
Are you sure it isn't 30mm, the smallest I've seen on
Sony Mini-DV, anyway. B&H carries these (avoid
Bowers, though, if you can - horrible machining on
the ones I've tried (Tiffen is better for this - though
I dislike their filters...).
David Ruether
rpn1@cornell.edu
http://www.ferrario.com/ruether
G
Guest
Guest
> David Ruether
> rpn1@cornell.edu
As you can see from the specs, the filter size is 25mm.
http://www.sonystyle.com/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/USD/SY_DisplayProductInformation-Start;sid=m-45vOO_jfY5p6PFhsYzt6yxJ5eZXF5Ch7E=?CategoryName=dcc_DICamcorders_MiniDVHandycamCamcorders&Dept=dcc&TemplateName=item%2fsy_item_b&ProductSKU=DCRHC40
If that long link doesn't work, it's the model DCR-HC40 which you can search
for at www.sony.com.
B&H Photo and Adorama do not carry step-up rings in 25mm size. That's my
dilemma.
Jim
G
Guest
Guest
news:g7pec.8401$oG6.7988@newssvr23.news.prodigy.com...
> > David Ruether
> dilemma.
Ah, so it is...
Would be nice if these camera makers didn't keep coming out with
new odd filter sizes... Best: get a 25->30mm or 37mm step-up
ring when it is available so you can use "standard"-size accessories
(37mm is best for this...).
David Ruether
rpn1@cornell.edu
