Still need help
Kinnie
Commendable
Dec 25, 2016
6
Hey I made an another ask community yesterday but I need more options plz tell me a motherboard and a processor to get. Hes my last thread http://www.tomshardware.com/answers/id-3338833/technical-support.html
GTX 1050 TI 4gb WAS Planning to get ASUS ROG CROSSBLADE RANGER FM2+ AMD A88X (Bolton D4) SATA 6Gb/s USB 3.0 HDMI ATX AMD Gaming Motherboard
AMD A10-7870K Godavari Quad-Core 3.9 GHz Socket FM2+
95W AD787KXDJCSBX Desktop Processor AMD Radeon R7
But people said it was a poor choice.
Okay, you already own the 1050 Ti. So three ways to go, lower price, current max performance or upgrade potential
Lower Cost
PCPartPicker part list: https://pcpartpicker.com/list/ZqXzGf
Price breakdown by merchant: https://pcpartpicker.com/list/ZqXzGf/by_merchant/
CPU: Intel Core i3-7100 3.9GHz Dual-Core Processor ($116.99 @ SuperBiiz)
Motherboard: ASRock H170M Pro4 Micro ATX LGA1151 Motherboard ($60.98 @ Newegg)
Video Card: EVGA GeForce GTX 1050 Ti 4GB SC GAMING ACX 2.0 Video Card ($144.99 @ B&H)
Total: $322.96
Generated by PCPartPicker 2017-02-22 10:37 EST-0500
Max Performance
PCPartPicker part list: https://pcpartpicker.com/list/zvhwHN
Price breakdown...
I wouldn't recommend ANY AMD purchase right now. The Ryzen release is close.
You are buying a discrete NVIDIA graphics card. There is no reason to buy an A10 with built in graphics. An 880K should be cheaper and generate less heat. But AGAIN, don't buy any AMD CPUs right now IMO.
The big response here is wait two weeks for Ryzen to be release by AMD, chances are very good that there will be much better options for you at that time and you could save a lot of money.
For Intel, first here is what you proposed entered into PCPartPicker
PCPartPicker part list: https://pcpartpicker.com/list/6m3GtJ
Price breakdown by merchant: https://pcpartpicker.com/list/6m3GtJ/by_merchant/
CPU: AMD A10-7870K 3.9GHz Quad-Core Processor ($149.89 @ OutletPC)
Motherboard: Asus CROSSBLADE RANGER ATX FM2+ Motherboard ($149.99 @ SuperBiiz)
Total: $444.87
Generated by PCPartPicker 2017-02-22 09:11 EST-0500
So around $450 budget. And here is what I would suggest. For around the same price you will get an i5-7500
https://www.cpubenchmark.net/compare.php?cmp%5B%5D=2531&cmp%5B%5D=2929&cmp%5B%5D=2910
And an RX 480, both much better components.
http://www.videocardbenchmark.net/compare.php?cmp%5B%5D=3595&cmp%5B%5D=3566&cmp%5B%5D=3533
But wait for Ryzen, you could save a lot of money for similar performance. Only about two weeks for release.
PCPartPicker part list: https://pcpartpicker.com/list/3vDsPs
Price breakdown by merchant: https://pcpartpicker.com/list/3vDsPs/by_merchant/
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor ($196.33 @ OutletPC)
Motherboard: ASRock H270 Pro4 ATX LGA1151 Motherboard ($98.98 @ Newegg)
Video Card: PowerColor Radeon RX 480 4GB Red Dragon Video Card ($164.98 @ Newegg)
Total: $460.29
Generated by PCPartPicker 2017-02-22 09:37 EST-0500
Lower Cost
Total: $322.96
Max Performance
Price breakdown by merchant: https://pcpartpicker.com/list/zvhwHN/by_merchant/
Motherboard: ASRock Z170M Extreme4 Micro ATX LGA1151 Motherboard ($101.98 @ Newegg)
Total: $443.30
Generated by PCPartPicker 2017-02-22 10:39 EST-0500
Upgrade Potential
PCPartPicker part list: https://pcpartpicker.com/list/yDTgKZ
Price breakdown by merchant: https://pcpartpicker.com/list/yDTgKZ/by_merchant/
Motherboard: Gigabyte GA-Z270X-Gaming 5 ATX LGA1151 Motherboard ($180.91 @ Newegg)
Total: $442.89
Generated by PCPartPicker 2017-02-22 10:34 EST-0500
