Still no audio/sound in my windows 7 64 bit
BlazeSandwich
5
i plugged in my kworld g6 gaming headset,it automatically turn to a default device.But there is no sound.it says no speakers or headphones plugged but they are plugged.When i unplugged my headphone,it return to the speakers but saying no audio output device is installed...its been 4 months of researching please help...im so sick of this
What do you mean? my sound on device manager:Conexant SmartAudio HD
Intel(R) DisplayAudio
first,I installed the intel(R) DisplayAudio but nothing happened.Then,I Installed the Conexant SmartAudio HD.an error says could not find the device for this driver. ???
"Then,I Installed the Conexant SmartAudio HD.an error says could not find the device for this driver. ???"
And from your first post: "it return to the speakers but saying no audio output device is installed"
Those two errors together lead me to believe that the Conexant audio chipset in your laptop or PC is faulty.
If it's a PC, you can fix by installing a new sound card in to a PCI expansion slot.
If it's a laptop you obviously can't do that. You'd have to buy an external sound controller which plugs in to a USB port.
I just bought a 7.1 channel usb :http://www.amazon.com/Channel-External-Sound-Audio-Adapter/dp/B007HISGRW/ref=sr_1_5?ie=UTF8&qid=1447139995&sr=8-5&keywords=7.1+channel+usb
When i plug it,the sound turn to a PnP sound device.then,i plug my headphone in it.nothing happens.Still no audio output device is installed
Then,i plug my sonicgear speakers,still no audio.when i plug the sonicgear,even without the usb still have no sound
