Stock case fans with a aio radiator?
koperan
72
I have a Corsair H100i v2 and i replaced the stock fans with two Noctua NF-F12 iPPC 3000 PWM fans right now my radiator is mounted on the top of my case with the fans in push exhaust config,
my case came with 3 front intake fans Im trying to see if i can mount my radiator upfront and still keep the stock led fans... so the the stock fans would be push and the Noctuas in pull as intake and put the stock corsair fans on top to get the hot air out of my case?
case fan specs
MAX. Speed 1200 +/- 10% RPM
Airflow 29.8 CFM
Static Pressure 0.7mm H2O
Sound Level 20 dBA
thank you
I'm trying to see if I bring cooler air thru the radiator from outside the case my temps will go down a tad... And because the front fans are intake I need exhaust fans so I figured if I move the radiator to the front blowing air in and use my stock corsair fans on top.
And than you are going to heat insides. Touch your rad when it's at hottest or feel air coming out of it, it shouldn't be hot at all, barely warm. It's pump and cooling body that get higher temps and contact with CPU is the hot spot, everything after that gets progressively cooler and rad is coolest of them all.
