Hello,
I am in the process of finalizing a build I am doing for my friend. He was planning on buying a console but I talked him into getting a PC instead and offered to build it for him. Here are the specs:
- Intel Core i5 2500 (non k)
- Intel DQ67EP Mini-ITX Motherboard
- Sapphire R9 380 Compact ITX
- WD Caviar Blue 1tb 3.5" HDD
- EVGA 500 W1 80+ Power Supply
- Silverstone Sugo SG13 Mini ITX
- Stock Intel Cooler
- Generic Front Intake Fan (approximately 1200-1300 rpm)
I wanted to go with a mini ITX build because of the portability and to make it most like consoles. I had a tight budget and this was the best I could get in a mini ITX form factor. My problem is the thermals. I know the stock fan is sub par but it assumed it would be fine since we are not overclocking. I get usually low 40s on idle but it gets to the 90s under stress tests and in game and will auto shut down if run for too long.
I need some suggestions on what I should do. I first had the power supply drawing cool air in the top but that had worse temps than I have now. I flipped it over to act as an exhaust and it lowered idle quite a bit but under load it didn't make much of a difference (probably because the power supply's fan doesn't seem to spin any faster under load). I also don't like feeding the power supply such hot air all the time. What would you suggest I do to make this build work? I don't have much money to work with. Would you suggest getting a better intake fan such as a pwm fan that can reach higher speeds? or should I invest in an aftermarket cpu cooler? If so, which one?
Thanks for your help!
