[SOLVED] Stock cooler OC'ing on ryzen 5 1600 temperature question.
Apr 4, 2019
17
So I overclocked this cpu to 3.9 on stock cooler with voltage at 1.2875 stable.
After a couple days of stress testing it it peaks around 85c with max load, which i'm a gamer so i don't hit that often.
Is that too hot ? Should i drop down the voltage/oc a bit? I'm not too familiar with what temps are good for this cpu.
Oct 15, 2018
13
Cooler upgrade. I m using a cryorig h7 plus and i replaced the fans with two corsair ml120 pro blue fans. When i first got it it had their balace fans then i got their performace fans( really loud at full speed) then the corsair
clutchc
Herald
Totally with ryzen master. The program i used was cinebench and prime95
Then I guess you can lower the OC if you want better temps, or upgrade to a better cooler. The stock cooler is damn good, but not really made for OC'ing much.
This would be a nice low cost cooler that would do the trick (did for me) and look good too.
