Stock Cooler Temps
noobswaggins
7
I am using a stock cooler on i5 3470 and getting avg. temps about 40C by coretemp.Under load it reaches 60C.
Are these temps. OK??
Also i believe that my paste is dried out cuz when i checked it yesterday it didn't seem to stick to my fingers. So if i change thermal paste would it be OK? or i should consider buying a cooler.
Also is this compatible with my socket (LGA 1155) :-
http://theitwares.com/thermalright-cogage-true-spirit-cpu-cooler?filter_name=cogage#!prettyPhoto
Thanks in advance
Well then i'd be applying new layer of thermal paste.
What about that cooler.??
I believe that the link you gave was to a newer version of this cooler.
the right link is maybe http://www.hardocp.com/article/2009/07/23/intel_core_i7_heatsink_roundup_q309/5#.U5gpmfmSxvU
And it says that it supports only LGA 1366
Well then i believe that this cooler is of no use to me ..🙁
The cooler master Hyper 212 is actually out of budget for me . -_-
Is Deepcool GAMMAXX 400 any good??
or the GAMMAX S40?
Also would they fit my cabinet??
What about those coolers i mentioned??
