Stock CORSAIR 460X RGB fans in case humming/buzzing
timoetimoe
13
I have had the Corsair 460x RGB case for over 6months now and no problems but recently the stock corsair fans that come with it the bottom 1 on the front that i haven't touched has started buzzing/humming noise very noticably i did remove some dust but if i let it spin then put my finger in the centre which stops the fan from spinning after its completely fine what do you think the cause is?
Try gently tightening fans down. Or loosen if tightening does not make a difference.
Don't go overboard. Just incremental changes to see if the hum or buzz changes or permanently stops.
