StupidNoob Reputable Jun 24, 2014 146 0 4,680 May 26, 2015 #1 I would like to find a way to lower system noise by changing the stock cooler or fan but I don't want to spend any more than £15, what should I do? I have the amd stock cooler by the way (8350)
Solution Eximo May 26, 2015 Tricky with such a low budget, not sure you would see much improvement. http://www.amazon.co.uk/dp/B007BVCBOE/?tag=pcp0f-21 http://uk.pcpartpicker.com/part/zalman-cpu-cooler-cnps80f Here is a popular budget choice at £17 http://uk.pcpartpicker.com/part/cooler-master-cpu-cooler-rrtx3e22pkr1
Eximo Titan Ambassador May 27, 2010 28,408 5,782 144,340 May 26, 2015 Solution #2 Tricky with such a low budget, not sure you would see much improvement. http://www.amazon.co.uk/dp/B007BVCBOE/?tag=pcp0f-21 http://uk.pcpartpicker.com/part/zalman-cpu-cooler-cnps80f Here is a popular budget choice at £17 http://uk.pcpartpicker.com/part/cooler-master-cpu-cooler-rrtx3e22pkr1 Upvote 0 Downvote Solution
StupidNoob Reputable Jun 24, 2014 146 0 4,680 May 26, 2015 #3 I was going for water but changed my mind at the end Upvote 0 Downvote
