Approximate Purchase Date: Late Oct., Early Nov. [Asking for advice/confirmation now because the local supplier requests two-three weeks advanced notice for search and transport of not-readily-available parts]
Budget Range: ~$900-$950 (Local currency-converted)
System Usage from Most to Least Important: Gaming > All else
Parts Not Required: Keyboard, Mouse, Speakers/Headset, Monitor, OS [Will purchase these separately]
Preferred Website(s) for Parts: N/A [Using local supplier/shop]
Region of Origin: Southeast Asia
Parts Preferences: N/A
Overclocking: Yes, minimal [i5-2500K @3.8GHz+ on-air, after 1-year supplier warranty expires]
SLI or Crossfire: Never
Monitor Resolution: 1920x1080
Additional Comments:
This is a spec sheet that I will be providing to my local supplier. I would like to have it reviewed for possible bottlenecks, compatibility issues or sub-standard performance before I have the system custom-built by my supplier.
For the record, Low Power Consumption and Build Quality/Reliability are just as important to me as Price and Performance. For example, my current rig is a nearly three-year-old E5200 (OC'd to 3.0GHz)/4GB RAM/Radeon HD4670/1440x900 set-up that worked fine for games of that generation, didn't spike my electricity bill, and is still running relatively well today, only having met its match when I pitted it against The Witcher 2 (playable, but ave. fps is clearly below 30).
The main (and practically only) purpose of this replacement build is gaming at 1920x1080. Particular titles include: Star Wars: The Old Republic, Diablo 3, The Elder Scrolls V: Skyrim, StarCraft 2, Shogun: Total War, The Witcher 2 and any future RPG and RTS titles. I may end up playing Crysis 2 and Battlefield 3 at some point, but FPS is not really my preferred genre. I am hoping my build would max out RPGs and RTS at 30+ fps in addition to smooth playback of 1080p movies/clips (3D unnecessary); I can live with High or Medium settings for FPS for the lifetime of the rig (3-4 years). If it's relevant, I am accustomed to below-max Anti-Aliasing and Anistropic Filtering due to my 'budget gamer' history; this is the first time I will be purchasing a mid-range rig.
CPU: Intel Core i5-2500K (~$237)
MB: ASUS P8Z68-V LE (~$177)
RAM: Corsair Vengeance 8GB (2x4GB) DDR3-1600 (~$73)
VC: PowerColor AX6790 (Radeon HD6790) (~$148)
PSU: Seasonic X-560 560W 80+ Gold (~$127)
Case: Thermaltake Commander MS-I (~$59)
HDD: Western Digital Caviar Blue 1TB 7200RPM (~$71)
DVD: Lite-On iHAS-224 DVD Writer (~$22)
Additional Front Fan: Thermaltake A2492 120mm (~$9)
Total: ~$923 [EDIT: tax inclusive; approx. $824 before all taxes]
Notes/Reminders:
1) The links go to Newegg, but since I will not be purchasing from that site, the prices listed are my local supplier's prices as approximately converted to USD.
2) I do not intend to buy an SSD for now (if you compare Newegg prices to my local prices, you'll quickly understand why).
3) This rig will be single-card forever, and I am unlikely to upgrade the video card during its lifetime.
4) I intend to run this system stock for a year to keep myself covered by my supplier's warranty (this is in addition to per-part manufacturer warranties). After that, the only OC I intend to do would be to push the 2500K to at least 3.8GHz, and going up to whatever I can reach with just the stock cooler, maintaining safe temps and minimal additional power draw (which was a big reason I went with the E5200 back then).
5) I am open to the idea of adding an aftermarket cooler, but I am aware of space issues with regards to those and the relatively tall Corsair Vengeance memory modules. I am not aware if the Low Profile versions of those modules are locally available, and am building with the assumption that they aren't.
Questions:
1) The eXtreme Power Supply Calculator (@10% Capacitor Aging) lists my potential power draw at ~325W stock (this includes future USB gaming keyboard/mouse/headset), and 335W OC'd (@3.8Ghz, no Vcore change [I am assuming, from the reviews, that the 2500K OC's +500Mhz just as readily as the E5200]). It recommends a PSU capable of 375W stock and 385W OC'd. Will the 560W Seasonic be more than enough for this set-up, or should I go up one step and buy the 660W version?
2) The PowerColor AX6850 costs ~$194 locally, which is a $46 premium over the 6790. Is this one-step-up worth it for that premium? What if it's the PCS+ version (i.e. factory overclocked)?
Thank you in advance for your replies.
Notes/Reminders:
Questions:
I'm just listing the reasonable prices for these components.
