Stock Ryzen 7 2700x Temps are too high?
Jul 30, 2018
5
I put together a Ryzen 2700x build a few days ago and used the stock wraith prism cooler. I'm idling at the high 50s- 60s and gaming at the 80s. I feel like this is a little too hot. Should I change my cooling options (add case fans or change cpu cooler) or should I just trust Ryzen software.
Thanks.
That is a tad high-that cooler, even though its stock, is a pretty capable one. Are you overclocking at all? Have you modified the voltages at all? Can you try using something like HWmonitor and keep an eye on your voltages as sometimes some motherboard's like to use an insanely stupidly high amount on auto settings.
I have everything on the auto option in the ryzen master. I guess it's overclocking based on Ryzen's functions. If I'm gaming it hovers around 80-85, performance is fine.
