Question Stock v. Air v. AIO Coller - Ryzen Build
Oct 17, 2021
14
I'm building a gaming PC for my daughter. Here is the current build.
CPU - AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor $309.00
Motherboard - Asus ROG Strix X570-E Gaming ATX AM4 Motherboard $308.04
Memory - G.Skill Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory $119.00
Storage - Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive $139.99
Video Card - Asus GeForce RTX 3080 10 GB TUF GAMING Video Card $1535.00
Case - Lian Li Lancool II Mesh ATX Mid Tower Case $125.99
Power Supply Corsair RM (2021) 750 W 80+ Gold Certified Fully Modular ATX Power Supply $135.00
I have no plans to overclock. Do i need to upgrade the built in cooler for the 5600X? Can I go with an Air Cooler? Do i need any AIO.?
What air Cooler will fir in this case and is there a source that will tell me what will fit? I know about the Noctua D15, but not certain it will fit.
Thanks
boju
Ambassador
Stock cooler is fine if not overclocking but fan is noisy. If ambient temps can get a little warm, 25c~30c then aftermarket would be preferable.
D15 will fit with first fan raised for ram clearance. I have similar case, Mesh performance (same width 229mm) with D15 and Gskill Neos 4.32cm height ram and side panel just closes without touching. Your ram is 4.2cm tall.
Reactions: MadAlienist
Phaaze88
Ambassador
"Do i need to upgrade the built in cooler for the 5600X?"
More or less, because of RTX 3080 and noise profile.
"Can I go with an Air Cooler? Do i need any AIO.?"
Yes. No.
"What air Cooler will fir in this case and is there a source that will tell me what will fit?"
PCPartpicker, for the most part. It's not perfect though - then again, nothing is.
"I know about the Noctua D15, but not certain it will fit."
See below:
Lancool II Mesh max air cooler clearance: 176mm.
NH-D15, in the default position: 165mm. Front fan sits over ram - clearance of 32mm. Must be raised for every mm over that.
Ripjaws V is 42mm tall. Front fan now needs to be raised 10mm.
NH-D15 new height: 175mm. Just fits.
Note, not all dual tower air coolers have their front fan sitting over the ram.
Oct 17, 2021
14
Thanks I’m glad to hear of someone with a similar case. Clearance is a bit close. :giggle:
Oct 17, 2021
14
Yes. No.
See below:
thanks for the info. That’s a bit of a squeeze, but I’ll check it out. Thanks.
