Storage Help!!!! M.2 SSD vs PCIE? M.2 vs 2.5 inch SSD? 120GB 2.5 inch SSD and 1TB HDD or 250gb 2.5 inch SSD
PcNoob222
Commendable
Jul 4, 2016
124
Basically, what the title says my budget it around $150 AUD for storage and I am so confused with all the SSDs I am not holding heaps of files or anything just like steam, win 10 and movies. And I want a fast system. what's the best SSD to get in my price range? stuff like that. Btw here is my build so you can see whats compatible.... http://au.pcpartpicker.com/list/PGqk6X If you have any advice on that too it is much appreciated.
THANKS!!
loki1944
1,665
201
With such a limited budget I would recommend the 256GB Sandisk X400 SSD for $130 http://au.pcpartpicker.com/product/vyKhP6/sandisk-internal-hard-drive-sd8sb8u256g1122
Alternatively if you can stretch the Kingston SSD Now 480GB SSD for$160 http://au.pcpartpicker.com/product/Z8Lypg/kingston-internal-hard-drive-sv300s37a480g
However; if you want games and movies then you need more storage, a lot of new games are clocking in at 20-30GB apiece and low resolution movies at 700MB apiece. So best option is OS SSD and mechanical hard drive. 2TB HDD: $109 https://www.mwave.com.au/product/seagate-st2000vx000-2tb-sv35-35-7200rpm-sata3-surveillance-hdd-aa19755 120GB SSD for OS $62 http://ijk.com.au/branch/ijk/product_info.php?products_id=152858.
PcNoob222
Commendable
Jul 4, 2016
124
loki1944
1,665
201
loki1944
1,665
201
Not sure what is up with my post being greyed in:
In terms of perceivable speed on SATA III there isn't much notable difference between SSDs; I have Sandisk, Kingston, OCZ, Mushkin, PNY, Corsair, and Intel SSDs and couldn't tell you which one was fastest without benchmarking them.
The higher end speed you can find in M.2. and PCIE; the Samsung 950 pro series is on the high end of M.2. Speeds right now but costs $219 for the 256GB version and $385 for the 512GB version.
Honestly I would not trade a few seconds for the ability to store my entire steam library+movies.
PcNoob222
Commendable
Jul 4, 2016
124
samsung 850 evo series 500gb 2.5 good enough?
loki1944
1,665
201
Samsung SSDs are usually good to go; here's the review for that series: http://www.anandtech.com/show/8747/samsung-ssd-850-evo-review/11 .
Similar threads
