Hello,
I just disassembled my system to modify my loop and change the PSU, power cables and the SATA cables. (One for the HDD, the other one for the SSD) There is also a M.2 SSD.
After rebuilding the system, the boot screen (Press F2 to enter BIOS) appeared for very long time (1 - 2 minus)
In the BIOS I saw, that the system not detect any of my 3 storage devices. The M.2 SSD was never detected... But it worked and still works now, I can load Windows.
But when i disconnect the SSD the boot screen just stays for about 5 seconds. But still gets not recognized.
I have no clue and i checked the following things:
1. Default Settings in BIOS
2. Checked SATS Controller
3. Changed the SATA cables with some spare ones.
4. Checked if there are any conflicts between the lines due to the M.2 SSD.
Before disassembling the system I used the same ports. Therefore, i didnt try port 3/4.
Does anyone maybe have an idea why the storage doesnt get recognized and why it takes so long to boot when the SSD is connected?
Here my specs:
Case: Fractal Nano S
Mobo: Asus Strix Z370I
CPU: Intel i7 8086K
GPU: EVAA GTX 1080ti SC2
RAM: 32 GB G.Skill Trident Z 3200Mhz
PSU: Silverstone 800 Watt
M.2 SSD: Samsung Evo 960 265GB
SSD: Intel 545's 256 GB
HDD: Seagate Barracuda 4000 GB
And I'm sorry if the text isn’t grammatically perfectly correct. I'm doing my best
Best regards
UPDATE: I also connected an other HDD to Sata Port 3. Didn't work too.
I also noticed, that the HDD doesn't even start turnung. But I know the HDD's work and i also know the cable gets power...
Here my specs:
CPU: Intel i7 8086K
Best regards
