Question Storage problems
May 23, 2019
6
Best answers
I am building a high end storage computer and decided to use a m.2 ssd and a sata ssd and a HDD. I have a doubt whether can I have all the 3 at once. If so how to configure the boot to m.2 properly.
birne
365
4
4,965
Best answers
62
It should be no problem having three different kind of storage.
You just have to choose your m.2 ssd as the boot device in your BIOS.
Can you provide us with some detail to what hardware you have installed or are planning to install?
Reactions: ElectrO_90
ElectrO_90
Admirable
Jun 21, 2016
4,862
385
7,840
Best answers
339
I run 9 hard disks in my computer.
The easiest way to do anything, is if you are building it.
Only connect the drive you want windows on, in the computer - then add the other drives once you are satisfied with windows working.
Reactions: DMAN999
USAFRet
107,840
735
151,340
Best answers
18,162
Yes you can.
My current system has 6x SSD. Used to be a mix of SSD and HDD (long ago).
The only thing you need to be mindful of is which (if any) SATA ports are disabled when using an M.2 port.
This is outlined in your motherboard user manual.
Connect the other drives after the OS install is done.
Reactions: DMAN999
