Question Storing mobos /w CMOS battery
Slick_3
18
Is it necessary to remove the CMOS battery if it is going to be stored for long periods? Also, will the BIOS be effected if the battery has been removed for long periods or will it still be okay?
Slick_3
18
Is it suggested to leave them in or to remove them when storing for long periods? Does it harm it at all or is it just more convenient to leave them in? Does leaving them in drain the battery after many years?
How long?
Probably a non issue.
The drain is minimal.
If the battery should fail, they are cheap to replace.
The default bios settings will be available.
Probably more convenient to keep it in the motherboard so you don't lose the battery.
Similar threads
