Strange artifacts on Rqadeon 9800 Pro
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hello,
I own a Sapphire Radeon 9800 Pro since 3 weeks and the card is very fast.
I am running Windows XP, Catalyst 4.3 drivers.
I have the problem that I often get strage artifacts when I turn on
antialiasing. These artifacts show up as a vertical line in the left most
column of the display and in the first row of the display.
I have seen this problems also in non - antialiased apps, like e.g. 3DMark
2000.
This seems to me like a driver problem.
Any ideas?
Paul Brause wrote:
> Hello,
> fast.
> most column of the display and in the first row of the display.
> 3DMark 2000.
> Any ideas?
No not at the moment what resolution is this?
regards
@ndrew
On 6 Apr 2004 18:41:17 +0950, @ndrew wrote:
<snip>
>> 3DMark 2000.
<snip>
It does not seem to be resolution bound.
I ran 3DMark 03 in 1024x768 resolution today and there everything is ok.
The madonion XL-8R8 demo for example exposed artifacts in
640x480 with enabled antialiasing, without anti aliasign everything is
fine.
It seems to me that DirectX 9 apps are doing good and elder ones don't.
<snip>
Catalyst 4.4 seems to have cured the problem in some apps.
