Question Strange Display Issues
Octopicake
42
Hey guys. I think my PC is slowly starting to go. The problem isn't super bad right now, since I do have a temporary fix for it. Recently, my Computer suffered a BOD and I had to reformat after it froze multiple times up to the blue screen. It was doing alright for a day, but now for some reason the display screen will go black at start up. I still get the logos of the manufacturer of the screen and so on, and there's still a signal being detected, but there will be a black screen.
Now the fix I found for this is just replugging in my PCI-E to my monitor, and it seems to do the trick. Hasn't happened twice in a row, only once, every morning after I boot up the computer. The GPU is seated well enough, and isn't loose. I'm assume its not dead as well because I can still get readings from it. Is it just my PCI-E cord?
Octopicake
42
No idea without spec but probably just the PSU
And here's my pc specs:
Tablet/Laptop/Desktop/
OS:
CPU:
Motherboard:
RAM:
GPU:
HDD:
PSU make and age are helpfull
HWINFO from here https://www.hwinfo.com/download.php
Here's what I have for a PSU https://www.newegg.com/corsair-tx-series-cmpsu-750tx-750w/p/N82E16817139006
Here is the PC list. Ignore the Power Supply listed on there. Finding the exact model is kinda hard for me.
https://pcpartpicker.com/user/Octopicake/saved/#view=xrr27P
I got a DVI cable just in case, going to test it tomorrow morning. Also sorry for the delayed response.
