I recently tried the Gaming boost option in the MSI Command Center, for a very short time. At the same time i overclocked my graphics card a bit too quick (went up to +200 core clock) and too much and the game i was running froze (i was checking the temperatures while running pubg).
Everything seems to be working fine after reseting the overclocks however I noticed how my Monitor makes a buzzing constant noise (it seems to be an EMI) when i start any games or do anything that makes the gpu work. I tried turning down the graphics on my game and the sound seems to be correlated to the gpu work load. This sound doesnt go away when muting the sound. I am currently using an audio jack together with the dvi-d for my monitor.
I first thought it had something to do with the increased voltage caused by the gaming boost option. However reseting the default settings didn't change anything. Changing the audio jack port seemed to reduce the noise even when having my gpu working at a high load. After changing that the sound is so quiet that it doesnt really bother me however since I am a novice on Hardware i was wondering if this issue could be causing damage to my computer.
My temperatures are completely fine on the motherboard/gpu/cpu and i checked with multiple programms. Could i have broken something on the motherboard by changing the voltage with the Gaming boost setting? or did something on my gpu break and is now interfering with my motherboard audio ports?
My specs are as follows: intel core I5-7600k
Msi Geforce gtx1070 8g armor oc
Msi z270 Gaming M3
If you need any more infos let me know its my first time making a thread about pc related stuff
Thank you so much.
EDIT: I tried to start a game of cs:go and the noise was pretty loud even tho the gpu wasnt very loaded. Somehow it seems to correlate more with fps than anything
2.EDIT: i tried some more stuff
after reading alot of different forums it turns out my monitor volume was set at 100 and turning it down affected the sound and made it almost non-existent at 60%.
Also i plugged in my headset (hyperx cloud2) into the same audio jack and i heard no noise. it seems to be an insulation problem with my cable. Its a bit strange how it happened now that i tried to overclock my pc since i didnt have that issue until then.
i will try to get some other cable asap to see if its just a problem with that one.
Msi z270 Gaming M3
Thank you so much.
