Question Strange monitor fault - blue tint
May 3, 2019
Hey Guys,
I have a new Asus VP28UQG monitor, it has been working absolutely fine (except won’t display output from my SP3), today it has developed a weird blue tint over a 3rd of the screen.
Added a picture if that helps.
Tha ks
Pic
May 3, 2019
Reseat the cable for it at both ends (the monitor and PC). Try the monitor on another system. Try a different cable.
Process of elimination.
Sorry should have said that (daughter was being annoying)
I’ve tried PS4, Laptop (DP) and Desktop (HDMI) all have the same issue.
dudio
Admirable
If with using 2 different connection and sources to the monitor, you still get the same fault, it would seem the monitor is the issue. You could try unplugging it for a minute (power cord) and see if that helps. Sounds like it is defective tho, and being new, it should be returned
