Problem:
- If I left click on mouse and drag something, i am unable to do it completely. This makes it difficult to use any app which requires extensive use of mouse or drag/ drop feature. E.g if I have to drag a text file from a explorer folder and drop it in notepad to open, the file is released (dropped) even before I can drop it in the app.
I am not able to drag anything for more than 1 sec or few pixels on screen.
- Same issue happens with usage of right click functionality. eg i use gestures using right click and I cannot use them completely.
- This also happens when I use the touchpad. So the same issues with both mouse and touchpad
what I know is not an issue:
things I tried:
I use a Windows 11 machine, upgraded from Win 10. The upgrade was done several months ago, but the issue only started since a week.
Anyone faced something similar?
Thoughts on how I can fix this?
Thank you in advance
- not an issue with actual mouse as I have tried with another new mouse and have the same issue
- When i vpn using citrix into a work
things I tried:
- System file checker full scan
- Windows update and latest drivers installed
- trying new mouse and reinstalling drivers
