today when i tried to open my pc , a strange noise came out ( i cant describe it 😀)then some fan (i think the processor one -i dont know as it is inside the case ) made a sound as it is working @ it's 100% speed then everything calmed down
rebooted several times but nothing happened (normal start )
specs:
core i7 860
gpu sapphire 5850
2X2 kingstone ram 1300
psu osz stealth & stream 600w
case cooler master 330
so what do you think ?
(well another small problem happened in the past , it may help you to analyze the problem when it first came it was with 2gb ram only & later i bought another 2 gb and when i put it in , the mobo gave an alert so i changed it's places several times until everything become normal )
specs:
core i7 860
gpu sapphire 5850
