Hi,
I am new to the forum. After a lot of attempts to diagnose a recent
PC problem I think that I need some help...
The problem appeared out of the blue. When the PC starts the booting
routine, after the post I get continuous fast and short beeps that do not
stop. The strange thing is that I have video, I can see the BIOS boot
screen normally but the computer is slugish as hell! In the BIOS screen
you press a key and you get a response 8 seconds later...
Something similar might happen if you try to boot a PC but you keep
pressing continuously a random keyboard key. In my case the problem
is the same even if you do not connect any keyboard or mouse.
The setup:
Motherboard ASUS CUSL2-C
CPU Intel P3 1.4Ghz Tualatin on a 370 converter socket
Memory 512Mb PC133
400W FSP power supply
Video Card Radeon 8500DV All In Wonder
The PC was working perfectly for years now. I leave it on all the time
with no problems. Two days ago I switched it off and on and that was it..
It looks like the motherboard is working because it goes though the POST
sucessfully and it will tell you if you remove the memory or the vga card.
I've replaced the PSU but the problem remains. I removed the
motherboard and powered it with only the PSU the CPU, VGA and one
memory module. Same problem...
Any help would be appreciated!
Regards,
George.
The setup:
Memory 512Mb PC133
Regards,
George.
