I just built a new system and have been experimenting with different settings. Here's the system I have.
CPU: E8400 clocked at 4GHz (445x9) w/ Vcore at 1.325v
Heatsink: Thermalright Ultra 120 Extreme w/ SilenX 120mmx38mm (90CFM)
Motherboard: Asus Rampage Formula
RAM: Kingstom HyperX PC2-8500 2x1GB (clocked at 890MHz and 4-4-3-11 timings)
Video Card: 2x Radeon HD 4850 in CrossFire
Hard Drive: Western Digital 300GB VelociRaptor
Blu-ray: LG GGW-H20L
Case: Antec Three Hundred
Power Supply: Antec NeoPower 650 Blue
The Antec Three Hundred comes with a 120mm rear exhaust fan and 140mm top exhaust fan There's a side vent for another 120mm fan and room for 2 front 120mm fans. I originally built this with only the rear and top fans. I installed the heatsink/fan to push air toward the rear exhaust. These were my temps running Prime 95 for a couple hours with room temperature around 76-78F:
CPU - 54
MB - 38
NB - 52
SB - 44
4850 - 71
HD - 29
I decided to add the 2 front intake fans thinking it would improve airflow. Doing this adjusted the temps as follows:
CPU - 53
MB - 41
NB - 55
SB - 48
4850 - 75
HD - 26
Interesting. Doing this actually made my temps go up by quite a bit (except the hard drive). So I turned the front fans around and made them exhaust, giving me 4 exhaust fans with air intake being the side vent (no fan). Now my temps looked like this.
CPU - 60
MB - 31
NB - 48
SB - 40
4850 - 69
HD - 32
All the chipset and system temps went way down and the CPU and hard drive temps went way up. I thought this seemed a little strange so opened the case and watched as the CPU temp came down to 53 and all the other temps jumped up another 4-6 degrees.
So now I need to decide which components I want to keep cool. I wanted to lower the NB temp to see how far I could push the FSB. When I tried doing a 533MHz FSB and setting the NB voltage to 1.55, the NB temp went up to 80. I don't really like the idea of my CPU running 6 degrees hotter though. What do you guys think?
CPU - 54
MB - 38
NB - 52
SB - 44
4850 - 71
HD - 29
CPU - 53
MB - 41
NB - 55
SB - 48
4850 - 75
HD - 26
CPU - 60
MB - 31
NB - 48
SB - 40
4850 - 69
HD - 32
