Today, I was installing a HDD from my old work computer. I got it in there and hooked up. I had to take a memory stick out to slide it into the floppy bay cuz i was outa room in the drive bay. Hooked it all up, put the stick back, and powered up. All the lights and fans come on for about a second or two, then turn off.
I looked into it online. I took my whole computer apart and outa the case. Hooked it all up on a piece of cardboard, with just the motherboard and cpu power attached, shorted the power switch and she came on.
Next, I added the video card and hooked it up to a monitor. It posted and was sitting there cuz I had no harddrive attached.
At this point I thought everything was ok, so I put it all back in the case and still the same damn issue. After swearing at the ceiling for a second, I hit the power button again, holding it a little longer than normal, maybe a second or two. Now it starts right up. It said something about checking the bios because of some error, so i just checked everything, saved and started windows 7. Has been running fine the rest of the day, until I tried to restart. Instead of restarting, it just shut off. Was pulling the same crap again til I held the power down a little longer and it just booted like normal.
It seems to me that all my components are working, which is a good thing, but I have no idea what is causing this issue. Maybe the power button is messed up, I dont know. Anyone heard of this problem before?
Thanks
Z
Thanks
Z
