Strange problem with Geforce3 & Wireless Internet
Fyllm
Hi all. I'm having some real issues with my wireless internet connection and my graphics card. Sometime ago I got wireless broadband from a local company called DLS internet up here in Illinois. Anyway I got it installed and it worked great, but when I went to run any type of game or graphical intensive app while my internet connection was active in the background I'd get severe graphical choppiness. Disabling the internet connection solves the issue, but I need it connected because my computer acts as the gateway for my home network as well as the fact that I want to play online games. I called Dell and they suggested I reformat my system, while another friend of mine told me to switch my network card to another PCI slot. I switched the card to another slot to no avail, but something funny happened when I reinstalled the OS. Right after I formatted and reinstalled WindowsXP Home and connected it online while running a game, everything worked fine! Then I upgraded from directx 8 to 9.0 (when another application I installed demanded it) and the same dang problem returned. DOH! I've tried upgrading my video driver to see if that helps (nvidia says its directx 9.0 compatible) but the problem remains. Any ideas?
System Specs-
-Dell 8200 2.0Ghz Pentium 4
-1 Gig PC800 RDRAM
-80 Gig 7200rpm HD
-Nvidia GeForce3 Ti200
-Windows XP Home
Just a guess but
Direct play in DirectX does deal with the network traffic! Isn't that right?
I would try a different NIC and if it does the same(my guess is it would) u may have to replace it otherwise reinstall os and stay with directx 8
I can't believe your video card is messing up your internet connection. DirectX9 could be the problem here.
Check "dxdiag.exe" using Run. And open the network tab and see whether there's any incompatibility problems in Direct 9 and to your network card.
<font color=blue>
My computer is <b>sooo fast</b>,
It finished <b>SETI</b> in <b>10 seconds.</b>
<font color=blue>
Checked dxdiag. No incompatabilities across the board... (So it says.) I guess I'll just get a new networking card and see if that works. (Hopefully)
