I built my PC a year ago and in the last 2-3 months or so it has a problem of freezing. So after searching on google I assumed that the RAM (Ripjaws Gskill 2x4GB) was at fault, so I left one stick in the mobo and took the other one out and the PC ran fine for a about 3 days and then the problems started again, so I thought that particular RAM stick must be faulty, and I changed this one for the other one, and the same thing happened - the same thing happened; it made the problem go away for 2 days and then the freezes started again. Any help much appreciated, thanks.
PC Specs:
AMD FX 6400
GTX 760
Windows 7 64Bit
Asus M5A78L-M/USB3 Motherboard
Western Digitial 1tb hard drive
PC Specs:
AMD FX 6400
GTX 760
Windows 7 64Bit
