Strange problem
abdurrehman
34
I've got
K7N2G-ILSR ; XP 1700+ ; 2x256 Crucial DDR333 ; Fire GL8800(128 MB)
The day i got it o/c to 1940Mhz (155*12.5) and 6.75 vcore with inbox HSF, for ram its 2-2-2-5 running in synch.
and scored 10K 3D marks, then i starting running it at defaults. BUT now when after a month i again o/c it with the same values i am getting 8800 3D marks.
I've not changed anything. So as to solve the problem i did a clean install.... no use. I'm not grasping the exact point.
Are you absolutely sure you use exactly the same settings?
And have you installed any software that is running in the background in that month?
My CPU fan spins so fast that it creates a wormhole 😱
I know u did a clean install maybe you have used new DirectX or Videodrivers or maybe a windows automatic update? Bios update? If no to all above then check all your BISO settings and shutdown all backgroundtasks in windows! Runa again if still 8800 then maybe the Videocards ramspeed ought to be checked.
GL
Turk
