Strange Process using 99% of cpu
Apr 6, 2018
43
So on my Windows XP server there is a Proccess called "enigma_av.exe" any one know what this is? because if i kill it it just starts again..... and it uses 99% of the CPU constantly
Ilya__
118
9
It could have been attached to a software that was installed on this machine. An infected .exe that was run off a USB-stick, there are many ways.
190221
527
95
you can download and run malwarebytes on that, you may have to temporarily expose it to the internet so it can update definitions
It should clean it up
As a side note, one doesn't really need to get 7 to avoid viruses. It's just as easy to hose a windows 7/8/10 system if you don't know what you're doing.
Consider using an antivirus to scan downloads from the internet before launching them, and also stay away from shady websites.
Apr 6, 2018
43
ok so at this point i have confirmed its definitely a virus... because its preventing Malwarebytes from installing/starting the install process... and then avast doesn't detect a thing...
