Strange thing right after bootup
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Hi all,
The last days when I boot up my Inspiron 5100 laptop, it starts
normally, then when I try to launch any program, whether it be a web
site or a program, it will not do so. Doing a warm or cold boot does
not seem to help although I can't be sure. It seems that after some
time goes by, it begins to function normally once again. Don't know
what else to say, any thoughts?
Fox
G
Guest
Guest
Have you tried starting the task manager to see what the CPU load is? How
about monitoring the drive activity light or checking the event logs?
<lwfox@frontiernet.net> wrote in message
news:fhodl0h33c755npl648m4rq3n8j0dppu92@4ax.com...
> Hi all,
> time goes by, it begins to functi onnormallyonceagain.Don'tknow
> Fox
fox
28
No I had not, will look into that.
On Sun, 26 Sep 2004 18:06:25 -0400, "MrMike6by9"
>> Hi all,
>> Fox
G
Guest
Guest
try restoring back to an earlier date, one that you recall when it did
work...
start-allprograms-acessories-systemtools-systemrestore... then follow
prompts.
> Hi all,
> Fox
fox
28
Good advice, I will see what I can do, thank you
On Mon, 27 Sep 2004 13:59:25 GMT, "Christopher Muto"
>work...
>prompts.
>> Hi all,
>> Fox
G
Guest
Guest
did you recently install windows xp service pack 2?
if you did it would be listed in add/remove programs... i have found that
several wireless network cards have crippling effects with sp2... currently
the only solution is to uninstall sp2 until microsoft address the issue.
"Fox" <lwfox@hotmail.com> wrote in message
news:r1chl095qj9mairr82lba8feqrkh3muhhm@4ax.com...
> >work...
> >prompts.
> >> Hi all,
> >> Fox
fox
28
Yes I did, and now that I think about it, that might be about the time
the concern began. That is a good thought, I may have to try that.
Thank you again..
On Tue, 28 Sep 2004 07:50:24 GMT, "Christopher Muto"
>> >work...
>> >prompts.
>> >> Hi all,
>> >> Fox
Similar threads
