I'm having a strange issue when I try to connect a USB 3.1 drive to my computer. I just built my first PC and I'm using it in a living room setup (connected to a TV / receiver). I pull out the keyboard / mouse, etc when I need to use the system, placing them on the coffee table, which I've integrated a USB hub into. I plug the hub in and then use a USB extension cable to connect the hub to the PC when I'm using it.
When I plug in my USB drive (it's a Corsair Voyager GTX 512 GB for reference), it kills all of the power in the hub temporarily. After a few seconds, it turns back on and everything is normal. This happens every time I connect it to the hub.
On top of this, I'm having a very difficult time using it. I've tried formatting it, changing between GUID / MBR, etc. It works flawlessly on my Mac (formatted to exFAT for compatibility with both Windows and Mac OS), but it's having a lot of issues with Windows, for whatever the reason. Any ideas?
