[SOLVED] Strange Wifi Behavior , Wifi Signal Range changes
Jun 29, 2018
88
Hello,
My Wifi Router is acting strangely ,
from Mornings to midday , it reaches all the rooms , and at nights until like 4AM the signal does not reach all rooms at all and devices will not connect nor see the router...
why ?
kanewolf
So there is just MUCH more radio frequency interference when there are people around you USING their WIFI. Your WIFI will only try to transmit if there is no competing signal that it is competing against. There is not much you can do. You can use 5Ghz as much as possible, but you will have to go wired for any real relief.
Similar threads
