I have a Soyo SY-6KD motherboard. It's a double proc with 266MHz, 440LX chipset. Everything is fine with WinNT 4 sp5.
I tried to install Win2000 and the installation cannot complete. It gives me a blue screen error message on restarting the computer saying "multiprocessor configuration not supported" as if Win2k did not detect the 2 CPUs. I tried to strip my system down to the VGA card, disabled caching and shadow memory in Bios (as suggested by the error message itself). I also tried an upgrade of WinNt and a clean install with a complete format but - alas - no improvement.
Perhaps I should try a Win2000 install with 1 CPU only to see if it can hook up to my motherboard...
Is there any suggestion in order to force a multiprocessor installation of Win2K (I know it should be automatic but, contrary to WinNT, I have no way to check it beforehand)?
Has ne1 got Win2000 installed on the same Soyo SY-6KD motherboard?
After about a dozen installs now I'm back to WinNT, but if someone can show me the light, I will be happy to try again.
Thanks.
Bibo
Thanks.
Bibo
