Question Strength problem while booting
May 20, 2023
37
The problem that sometimes when i try to start pc i am getting black screen and vga led on board light on but i think the pc boot to windows because i can hear every sound in windows with speakers (like when plug usb)
And to solve this problem i should wait few seconds and restart pc and it work fine this problem is recently appeared
And when this problem happened the gpu fan spin and not stopping as usual
I tried to :
Change monitor
Change cable
Clean ram socket and pcie
Change ram
Clean gpu
Update bios
Delete all driver and install them again
Clear cmos
My pc is:
My pc is
Asus b450m pro s
Rx 580 8gn
Coolermaster 600w elite v3
16gb ram
Ryzen 5 2600
1*m.2 128gb
3*hdd
Check in your bios to see if quick start is enabled, same for your windows settings fast start. If it is enabled try disabling it.
I tried that but problem still exist
The last thing i changed in computer before the problem appeared that i add hdd 2.5 500gb
And i was having 2 hdd
Do you think it can power problem that gpu dont get enough power when start at frist time and when restart it get the power that it need ?
