Stress test settings and temps
Silverion77
2,106
I got my computer up and running and plan to overclock my E2180
Just a couple of questions:
1) For ORTHOS and Prime95......it has several tests, Blen (some of everything), small FFT's, and in-place Large FFT's, what setting should I do to see if CPU is stable?
2) Also for Vista, does anyone know where a signed version of Coretemp is? I have Speedfan working, but CoreTemp isn't signed and won't run.
3) What are safe (not too extreme or right on the edge) temps for the CPU.
Thanks in advance for your help.
small FFT's for CPU. I dont know of a signed version of coretemp. You can disable driver signing on boot but its a PITA. I just use speedfan, it gives temps for CPU and cores.
As for temps, read the excellent sticky about temperature guides at the top of the forum.
