Question strix z270h gaming DRAM led on
Apr 26, 2022
so i replaced my hyperx fury 2400mhz 2x4 gb with corsair vengance 2x8 3000mhz, tried booting computer, everything turned on but no display, i reset the rtc with the 2 pins, it booted, the led changed to white, i got into bios settings, saved and advanced, then when the pc reset the dram led would go orange again, i’ve reset the rtc with the battery, the pc boots but then gets stuck on a loading screen
tried old ram same issue, did i fry my mobo?
