STRIX Z370 wi-fi connection issues
NextGear
Commendable
Jul 20, 2016
194
MOBO: ROG STRIX Z370-I GAMING
CPU: i7-8700 Coffee Lake (temp @ 32c)
Cooling: NZXT Kraken x52 + w/ NZXT H200i Case
Video: STRIX GTX 970
MEMH: DDR4 Corsair Vengeance 3200MHz
HD: 2 SDD Samsung 850 EVO
PS: Corsair AX860
I install a clean Windows Pro 10 64bit + ROG STRIX Z370-I GAMING DVD drivers.
I can't connect or log on to my home wi-fi network. I can see and detect my wi-fi network & others, but can't connect.
I have already
uninstall/reinstall wi-fi drivers + the LAN drivers.
reboot my router
troubleshooting with Settings → Network & Internet
troubleshooting with Settings → Privacy
went through the BIOS setting
can't ping outside
xx hrs online searching for a fix
OMG!, ASUS website has the worst drivers support
Need your help!! frustrated
lol.. I have all already try it, no luck. I also double check the MOBO and make sure there wasn't a wi-if on/off switch as well.
Can you describe what is happening in more detail? You can see your home network and you enter your network password and hit connect. Does it reject your password or it just fails to connect? Perhaps the problem is in your routers settings?
It fails connect or unable to connect to network. I have also notice network selection is constantly refreshing or cycling.
My router is N600 WiFi Cable Modem Router Model C3700
My password setting is correct for the router. I can log in with my other PCs/cell phones/games consoles etc with no problems.
