Thank you! The problem is that im not from usa and those things here cost like 300 dollars sometimes. Im buying an already made pc with all the parts inside and i want to buy the rx 570 one, thats why im asking. I really dont know which one to choose from those 2 and i needed help so yeah. Thanks for the answer once again!Going with the A320M you will limit yourself for storage and possibly cannot upgrade to the Ryzen 3000 series. However, here in the USA you can find a 8GB RX 570 for less than a 1050Ti https://www.newegg.com/Product/Product.aspx?Item=N82E16814930008&ignorebbr=1&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC--na--na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Those are the cheapest ones available on pcpartpicker. Also I would look at using the B450 motherboard instead of the B350.ZOTAC GeForce GTX 1050 Ti DirectX 12 ZT-P10510A-10L 4GB 128-Bit GDDR5 PCI Express 3.0 HDCP Ready Mini Video Card - Newegg.com
Buy ZOTAC GeForce GTX 1050 Ti DirectX 12 ZT-P10510A-10L 4GB 128-Bit GDDR5 PCI Express 3.0 HDCP Ready Mini Video Card with fast shipping and top-rated customer service. Once you know, you Newegg!www.newegg.com
It sadly doesnt have my country the problem with it is that every component in my country is expensive af like the pc i wanna buy has ryzen 7 has rx 570 etc and its 550 euros but if i want to buy only those 2 components they would be around 600 euros because the prices here are stupid thats why we buy already made pcs. So which one do you think its better for me to take the stronger graphics but weaker motherboard or the other way around?Depending on where you live you might have a pcpartpicker site for your country. There are 14 countries represented so you might get lucky.
As i said before i cant really buy other components i can only choose between those 2 pcs. The prices in my country are just dumb and ill probably change the motherboard and everything eventually in the next years but for now what do you think i should choose, and i use it for gaming btw nothing else.Well the thing is if you don't oc then the A320 is an option but personally i would not waste money on it.On the b350 the gtx 1050 ti is good maybe depends on game 1080p med settings in newer AAA titles like monster hunter world or AC its low settings.The rx 570 is a lot faster and cheaper in most countries.But like what was suggested try get a b450 i got mine for around 100 usd its not the best board but it does the job(in my currency the board is a little more i am just giving an example of what usa charge for it)
