[SOLVED] Stuck between 3 motherboard choices
Zealex
Commendable
Jul 27, 2017
8
I am finishing my rig and am torn between 3 x570 options:
Asrock x570 phantom gaming 4 (154)
gigabyte x570 gaming x (154)
ASUS X570-P Prime (149)
According to this list, the VRMS seems the best on the Asus? The asrock has intel lan and Realtek ALC1220 .
Not sure since theyre all at the same price point.
Getting x570 and hoping it works with the 4xxx that comes out. Would consider b450 but microcenter is basically all out of stock atm (no MSI max boards, no k4, etc)
Thanks
That kinda sucks. Well, the Asus or Gigabyte are ok, you’ll have to see what board has what you want. Or you could wait for new stock , up to you.
Zealex
Commendable
Jul 27, 2017
8
So you have a Micro Center near you?
The in store price of the Asus TUF is $189 and I’d suggest this over the Prime if your budget can swing it.
I have it and for me not a single issue and a step from the Prime.
theyre all out of stock for me unfortunately. Its either those 3 or I spend 200+ for something :/.
I was gonna just get a tomahawk max but alas its also...OOS, k4...also out of stock.
Everyone is gaming for the pandemic HAH.
